Discuss Leaking wet room in the British & UK Tiling Forum area at TilersForums.com.
Rich
To be honest I think the water has prob done a horrible amount of damage to the substrate. Cutting out the grout and replacing it with a Silicon joint (it would be worth getting a tiler to do this) will make that joint water proof but you said that there is holes in the grout further up. Even if you have somebody in to cut out and replace all the grout, the substrat will still be ruined. As gooner has said, the entire area should have been tanked. It seems that the installation wasnt done properly from start to finish.
Will
I dont doubt that it wasnt done properly given the plonker who did it ran the ensuite waste into a soakaway rather than the mains, I have spent two weekends relaying new drains to clear that one up already! I hate to think what he did in the ensuite shower cubicle as well in terms of waterproofing the walls. Do you think this is a job for a plumber/tiler?
Rich
Id get the recommended tiler in to have a look and if he says you need a plumber than take it from there. Some tilers do all the work others will not. The problem with going straight to a plumber is that they will almost always say that they will do the work themselves and very few of them know the details like the Silicon joints in the corners.
macten
1,158
Nottingham
Just been to look at this hoping remedial work would sort it but unfortunately requires ripping out and re-doing properly.
From what I can see looking up from the garage is a sheet of ditra laid on the floorboards (no sign of it being stuck down with spf) then 12mm thick MDF on top of that - all this on a floating floor.
Can put my hand up and feel the backs of the brown skirting tiles that are dot and dabbed at the very tops where the PB ends, below that there is nothing.
Other areas of the bathroom have tiles holding on with grout.
macten
1,158
Nottingham
Here's the shower waste through what looks and feels like MDF :
Here you can see Ditra onto floorboards, the MDF is then on top of this:
Where walls meet floor:
Reply to Leaking wet room in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
  • Sticky
Advice needed, noticed some grout that was cracked and tiles becoming loose in our en suite wet...
Leaking wet room
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
