rainsco
hi,
i get an invitation for a new schlüter training for the new products. i don´t like schlüter as much as the uk tilers do but this new produkt sounds interesting.
check it out here:
Homepage - Schlüter
i think i order a starting set and try it out. i don´t like the direkt profiles but hey i´m like tony and mitre is my live 🙂 but
the indirekt profil and the fixtures are a complete set and looking nice and easy to install.
greetings rainer
its not such a new idea this was done in 2010
very nice stair! one of your projekts? job of the year!!! maby!
i know its not a new idea but its a complete set easy to install. with all things that are needed and plug and play.
Yes one of mine, I have been done some nice houses but this was out of the ordinary and the house was on the market for 18,000,000 pounds
any more pics? what led system do you use? do you glue the stripes direkt on tiles or is it a rail system?
the tile is a 10 mm porcelain with another 10mm tile fixed to the bottom then bull nosed , a 10mm gap was left and a led strip was glued into this gap, the material came from Italy oversized and I had to cut in the stair case on site and make the risers , the bottom 2 steps were greater than 1200 and the factory made these steps with a joint through the centre which looked terrible so remade them on site and adapted the curved part so the joints where in line with the edges which made them less visible I also had to make an extra step piece as a scaffolder broke one while dismantling the scaffolding
thats a very nice idea.
i think the schlüter system is more easier and the stripes are not glued and so easy removable for service or something.
i like all these lightend niches or bathtub pedestrals but until now i don´t want to search for the right systems or someting.
i think i will buy a starter set and try to find a customer for that.
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
