Refresh On The Box Sets Of Tile Drill From 365-drills Drilling Holes 2016
Deleted member 1779
It has been painful (painfully slow!) BUT slowly I am refreshing the box set range for the diamond core tile drills.
There will be a new look box. It has different (stronger) hinges as well as stronger locks.
And now instead of offering TWO box sets there will be THREE box set options.
The third box set of tile drills was developed because I was really keen to offer the exsiting Bathroom Fitters Kit which is supplied as a clear clam shell into boxed drilling solution.
So this will give you more choice in tile drilling options. It will now be:
1) Box set "small" will cotain ten tile drills (ignore the pic) 5 x 6mm 2 x 8mm 1 x 40mm 1 x 30mm 1 x 16mm 1 x guide plate 1 x sponge 1 x cleaning hook 1 x box
2) Box set "medium" [Essential] will contain twelve tile drills 4 x 6mm 4 x 8mm 1 x 45mm 1 x 35mm 1 x 25mm 1 x 18mm 1 x guide plate 1 x sponge 1 x cleaning hook 1 x box
3) Box set "large" [Ultimate] will contain 30 diamond core tile drills.
Here is a sneak peak of how we are doing in product concept. Expect some more messages as we work through the prototypes:
The sets have been designed after feedback from tilers (like yourself) as well as retailers.
This forum which we have supported from the start has always been a useful two way conduit allowing us to adapt the product offerings as a result of your input.
This Bathroom Fitters Kit (above) at £49.99 [£41.66 + VAT] has always been the backbone to whatever we have supplied. At £7 a drill it offers execption value for money. However the feedback has been for a case to hold the contents. And so by bundling the water cooling sponge and the cleaning hook with it we can offer more. Not sure yet about the pricing structure. But working on it!
You can always check out current items at 365Drills.com
Agreed! However.... We have designed this rather nifty J-Hook. It's capable of pushing out all debris
in the 6mm plus other size diamond core tile drills.
It comes provided in the box sets. And is available as a seperate item.
The slots we cut into each diamond drill allow access for the bar to push out tile dust, plasterboard, grout, adhesive plus anything else that gets trapped up there.
I totally agree with you that out of the entrie range the 6mm is the most difficult to look after.
Better to use 8mm. But the market will not give up on 6mm and so we have to supply what the demand calls for.
I wish we didn't have to! But I hope that the use of the 365Drills J-Hook is a useful tool to get the longest life out of diamond cores.
Its a one off purchase. And they do last for ages (I have had mine for 3 years - still going!)
It's 2016 and we will be having a refresh of the box sets very very soon.
There will be THREE sets to choose from. And a slight rebrand
More follows...
hello there , I have been calling and calling you for the last week ,I have left you message after massage and still you don't reply , you must be doing so well you cant be bothered to look after the little people any more
Might be a little difficult getting hold of him at the moment. There is a thread somewhere that will explain.
I'm afraid 365 haven't been on the forum for a couple of months either so we can't really help.
Deleted member 1779,
Dan,
Dan,
