Deleted member 1779
It has been painful (painfully slow!) BUT slowly I am refreshing the box set range for the diamond core tile drills.
There will be a new look box. It has different (stronger) hinges as well as stronger locks.
And now instead of offering TWO box sets there will be THREE box set options.
The third box set of tile drills was developed because I was really keen to offer the exsiting Bathroom Fitters Kit which is supplied as a clear clam shell into boxed drilling solution.
So this will give you more choice in tile drilling options. It will now be:
1) Box set "small" will cotain ten tile drills (ignore the pic) 5 x 6mm 2 x 8mm 1 x 40mm 1 x 30mm 1 x 16mm 1 x guide plate 1 x sponge 1 x cleaning hook 1 x box
2) Box set "medium" [Essential] will contain twelve tile drills 4 x 6mm 4 x 8mm 1 x 45mm 1 x 35mm 1 x 25mm 1 x 18mm 1 x guide plate 1 x sponge 1 x cleaning hook 1 x box
3) Box set "large" [Ultimate] will contain 30 diamond core tile drills.
Here is a sneak peak of how we are doing in product concept. Expect some more messages as we work through the prototypes:
The sets have been designed after feedback from tilers (like yourself) as well as retailers.
This forum which we have supported from the start has always been a useful two way conduit allowing us to adapt the product offerings as a result of your input.
This Bathroom Fitters Kit (above) at £49.99 [£41.66 + VAT] has always been the backbone to whatever we have supplied. At £7 a drill it offers execption value for money. However the feedback has been for a case to hold the contents. And so by bundling the water cooling sponge and the cleaning hook with it we can offer more. Not sure yet about the pricing structure. But working on it!
You can always check out current items at 365Drills.com
