Guest viewing is limited
Discuss Leveling Compounds in the UK Tiling Forum area at TilersForums.com.
DHTiling
Brief description on the use of leveling compounds......dave....
Leveling compounds are ideal for smoothing out a subfloor prior to installing floor tiles.
Leveling compounds are cement based and are easy to apply. They will adhere well to both concrete and wood surfaces.
To ensure that the floor surface is level and rigid, a leveling compound may be needed, The leveling compound can be added to the floor to adjust for any dips in the subfloor.
The subfloor should be clean and dust free, prior to applying a leveling compound to your subfloor. If it is not, you may get a poor bond between the leveling compound and the subfloor.
Use the straight edge, to check how much leveling compound you will need, by running it over the surface of the subfloor to see how flat it is.
Note that leveling compounds set quickly. it is best to mix up small batches at a time.Start with your lowest points first and infill to get a nice level floor..
sWe
once the leveling compound has set can the tiles be layed or will you weight
till its dry?
Stephen
It varies between manufacturers... Many products are ok to tile onto after 24-48h, depending on layer thickness, but some require a full week or more to cure and dry out properly. You can compensate for that by chosing products which suit your time frames.
Bear in mind, that if you use a leveling compound which is tileable after 24h, it'll still need to dry out fully before you can waterproof it, unless you use a waterproofing compund which allows for vapor diffusion (the type you use on surfaces with rising damp).
Always read the specs and guidelines the manufacturer prints on the bags.
For additional pointers on SLC, check out my guides thread (link in my signature).
davy_G
how much are you chaps paying for slc?
I can get a bag of ardex low amonia latex for about 50 quid
I can get a bag of Technik (stinking) latex for a tenner plus vat.
The technik stuff is not as good as the Ardex but then at 40 quid cheeper i make do.
What you chaps paying?
I have used the gear you mix with water at about 25 quid a bag but in my opinion its not as good as the gear mixed with latex.
Reply to Leveling Compounds in the UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Help! New DIYer here - I’m preparing my bathroom floor to lay ceramic tile. Removed the vinyl...
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Leveling Compounds
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
