Discuss Leveling Compounds in the British & UK Tiling Forum area at TilersForums.com.
Can anyone recommend an easy to use slc suitable for pouring over ufh?
The ufh wires are about 2mm thick, and to avoid raising the floor height too much when its all finished, i'd like to pour the minimum amount of slc to cover it (say, 3mm). Is this depth reasonable? What is the minimum depth it can be used without cracking? Are all brands the same or can some be laid thinner than others?
Cheers
Jimbob
Anyone used Gypsum Based SLC over cable UFH - just wondered if it worth taking advantage of the higher thermal conductivity.
Mapei latex plan trade...excellent stuff to use and flows like a dream... does upto 10mm...
Is it OK to pour self leveling compound over wire uhf on insulation boards?
The having to prime the hell out of it to use a portland based adhesive...:smilewinkgrin:
Reply to Leveling Compounds in the British & UK Tiling Forum area at TilersForums.com
