Guest viewing limit reached
Levelling floor
tileform
Hi Guys
I have a porch to do but the floor is running out at an angle
The size is 2.5m x 0.7m and i need to level it to a height of approximately 45mm to suit the step into the house then tile onto it
Can anyone reccommend a low cost flooring compound or similar for me to use up to this height?
Much appreciated :thumbsup:
Are you wanting 45mm to zero? or can a new screed be added to the highest point too?
Internal or external?
Here's a guide on how to choose SLC. There are more factors to take into consideration than the thickness you want to pour it to.
Ardex makes some top notch SLCs. Have a look at Ardex.co.uk; they've got their products listed there.
Sir Ramic,
The slope itself is approx 15mm but i need to increase the height of the floor by approx 30mm overall to meet the step, so its going from 30mm to 45mm if that makes sense.
the porch is external too
And what is the step made from at the moment?
If its tiles then hack them off 1st, If its concrete then a sand and cement screed or concrete would be my choice.
the step is down to the bare brick and the porch has a concrete base
would it be cheaper to just screed the porch?
Ardex EB2 Mix would fit the bill. It's a screed which is tileable after just three hours. Frost resistant too, so it's suitable for outdoors use. You'd just need one bag for the job.
One bag??? are you sure?
Ahh one bag plus the added screeding sand .
Levelling floor
tileform,
sWe,
tileform,
sWe,
