Discuss Levelling System in the Australia Tiling Forum area at TilersForums.com.
X
xlilgemx84
Hi
I'm new on here and just had my floor tiled with 80x80 porcelin tiles.
I knew it was a hard job and would not get it perfect. After the job had been done I have now heard about the tile levelling spacer system and am now gutted that this could have been used as there's some uneven tiles!
Would it have made a huge difference?
One room had been self levelled first and the others had the small red quarry tiles underneath.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
http://www.tilersforums.com/threads/tuscan-leveling-system.42220/
Possibly yeah.
I've never used myself. My gripe with them is that if a tile is dipping you need more adhesive under it, and simply pulling he tile up risks not having a 100% solid bed. So I'd assume you need a sloppy mix so that it can run around under there and fill all voids. Then you're not really mixing the mix to the instructions; you're adding more water.
That said, the professionals who have used them seem to like them. So maybe I just need to have a go sometime. I don't actually tile anymore though.
I use the Rubi system when needed, they're part of my kit now.
Not actually for diy'ers or the newbie Tilers really, they take getting used to and there's a certain touch to them, but once mastered they're fast I think. But they don't do the job for u! They're only an aid that's why I don't think they're for the novice. As voids will form if not used correctly, it takes a bit of know how and experiance to know what's happening beneath the tile. But that's only my opinion, cos I know there's a lot of guys with theirs! Haha :D
No specific adhesive for the system, just use what u need for the situation. I'll admit u need to have a slightly wetter mix, but still well within tolerances. I can walk away in the evening knowing that when I return the next day it'll be exactly how I left it. How many times do u return thinking that you're sure it didn't look that way last night! :confused:
I know it's happened to me more times than I care to remember!
X
xlilgemx84
Thanks everyone would have loved to known before hand and would have paid for the system even if exspensive as I bought so many tiles!
They are all down now so could change them in a couple of years. Just put so much time into picking them and buying other materials.
Still learning about it all so next time will hopefully know a lot more and buy anything that will assist.
Is it best to use 60x60 but have got two large rooms that are in?
I always use them with porcelain planks now with a broken bond. Try to make it look as much like a natural timber floor as I can, and the answer to that is using lash clips as far as I'm concerned.
Reply to Levelling System in the Australia Tiling Forum area at TilersForums.com
Hi all I’m a homeowner and have just had my bathroom floor tiled and am requesting your opinion...
I am starting a large floor tomorrow in 1200 x 1200 tiles and am now thinking to myself should I...
Hi all, this is my first post and I am in desperate need of advice! Last year I had a porcelain...
Levelling System
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
