Discuss levels.. in the Australia Tiling Forum area at TilersForums.com.
Are you talking about the ones that are slightly fatter and have the groove things running the full length of the body? Glad you said that cos i have often wondered if they are any better. Cheers mate
They main thing with any level is calibrate it yourself though. Take it off the shelf and test it before you buy, this is the advantage of not buying via the net though.
Yep that's the one. Just pick one up, and you'll feel the difference in quality instantly! ;D
How can you calibrate it!?! You can test it, to make sure it's level, but I don't see how you can calibrate a level.. Although, I did hear a rumour that with some of the more expensive stabila's, they can be sent off, when they've gone out, to be re-calibrated..
Reply to levels.. in the Australia Tiling Forum area at TilersForums.com
