Discuss Lift ply or overboard? in the Australia Tiling Forum area at TilersForums.com.
K
kinglumma
Hi All,
a reasonably experienced diy tiler here! I know there's lots of threads on backerboard but can't seem to find what i'm after.
My kitchen is chipboard with 6mm ply on top, missus wants the scabby vinyl replaced with tiles.
A few questions:
  • The chipboard is pretty stable and the 6mm ply is nailed on top. Now i know no-one here will recommend tiling on top of 6mm ply so i was planning 6mm hardie backer board but is there any benefit to leaving the ply underneath or should i just lift it and replace with the hardie board?
  • There is a slight slope in one area, should i slc under or on top of hardie board?
  • I normally use bal products. Is there one adhesive that can be used for under the hardie board and on top for sticking the tiles?
Any advice greatly appreciated!!
Andrew
Reply to Lift ply or overboard? in the Australia Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Looking for advice on how much adhesive to use. I’ve taken on my first tiling project and found...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Tilers Forums on FB
