Do you have a little taste of it too....🙄Polymers add to the adhesive qualities and flexibility. The adhesive bag will give you the correct ratio to mix, often there is a range to allow a stiffer mix if needed.
A very simple, although very unscientific, test is to put your finger in the adhesive bed. If it doesn't stick to your finger it's unlikely to stick to a tile!
