Discuss Liftting Tiles with electric underfloor heating... in the British & UK Tiling Forum area at TilersForums.com.
timhuetson
Good Afternoon,
I am having problems with my bathroom floor.
Last year I completely renovated my house and decided to put an underfloor heating system in the upstairs bathroom, which is working fine apart from issues with the grout cracking and the tiles lifting in the heavy footfall area around the door.
The floor is made up of: floor boards, marine grade ply which is stuck down with no more nails, self - levelling compound in which the electrical underfloor heating is set in, then the tiles.
When we laid the ply we didn't nail it down - would this make the floor flex when it heats up therefore giving me the issues that I'm having?
It is also creaking under foot obviously with the movement.
What should I do - I cannot afford to lift all the tiles. Should I lift the offending tiles and see what is going on underneath, will these come up easy?
Please see picture below which highlights the issue, this isn't just happening in one place but several. (I have more pics if needed).
Please note I am not in the trade so need as much help as I can get!!
Thanks,
Tim.
timhuetson
Deffo no hope. Minimum ply 15mm WBP .
Sir Ramic, I'm really looking for advise. Are you saying that I will have to lift even the selfleveling compund and the tiles or just lift the tiles and screw down?
That would be a huge job and cost quite a lot... Surely there must be a fix?
Gazzer
A fix or a chance ?
Only way to fix is to use correct materials and correct methods. So the correct way would be redo the job.
The chance ? would be give your way a try....it may work or may not. You really cant expect professional tilers to advise any other way than the correct way as I hope no one on here would have used 4mm ply glued with "No nails" !
Reply to Liftting Tiles with electric underfloor heating... in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
