Guest viewing is limited
Discuss Liftting Tiles with electric underfloor heating... in the British & UK Tiling Forum area at TilersForums.com.
timhuetson
A fix or a chance ?
Only way to fix is to use correct materials and correct methods. So the correct way would be redo the job.
The chance ? would be give your way a try....it may work or may not. You really cant expect professional tilers to advise any other way than the correct way as I hope no one on here would have used 4mm ply glued with "No nails" !
I suppose its worth a chance and then if it doesn't work do a proper job.
I was new to laying floors etc, so this has been a learning curve and I should of sought advice in the first place.
But thanks for the advise its much appreciated, have you seen this happen before?
timhuetson
is it the ply thats at fault or is this creaking the sub floor not being prepared either and has movement though?
either way screwing through levelling compound will not solve it imo and re using the tiles is another issue
there is no quick fix its been installed incorrectly
I do think its the ply and glue thats at fault... its flexing under the pressures and when getting warm etc.
Thanks for your advice.
Gazzer
You may as well give it a try as it wont cost much. if it fails again then you know what to do.
Reply to Liftting Tiles with electric underfloor heating... in the British & UK Tiling Forum area at TilersForums.com
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
I have a customer who lives in a 200 year old property. The lounge floor he wants tiled which...
Had new bathroom by a builder who has subsequently gone bust and after 6 months the floor has...
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
