Lights Flickering when turning on at different switch
  • Thread starter Thread starter hollys
  • Start date Start date
Hi, wondering if anyone could help me. The main light in my kitchen works off two different switches, one on either end of the room. One of the switches is a 3 gang switch which also connect to some spotlights and outside lights.
When turning on and off at one switch it is fine, but then if you go to turn the lights on with the opposite switch the lights flicker until you turn them off and on again with that same switch. I have checked the sockets for loose connections and checked the bulbs and all seem okay so a bit stuck on what the issue could be as the other two sets of lights controlled in the 3 gang switch work perfectly.
Continue reading...
Electrical Advice
Tags Tags
None
hollys,
hollys,
