Discuss Limestone detiorating ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Ttt1601
not shiny no, slightly darker it is a tumbled stone, but has had some sort of polish or hone on it as 98% of the surface each is smooth like honed and filled it just the edge and a couple of pit/ veins that have any kind of texture to them, think i will try and strip, buff them reseal, but will test first on a stone and talk to the customer, cheers bob will report back when ive had a play round with spare stone
Ttt1601
yea was thinking something similar, but want to try other options first as the supplier isnt going to pay towards anything, and the customer really doesnt want to cover cost i can tell, and i dont mind doing a bit of work free ( as its a small village full of money and it only makes me look good lol) to see if things work before it comes to that level of work and i want to be paid for it, but will have to speak to the customer again. what diamond pads to you use @callatiler ?
Blunt Tool
Speak to @ATSDiamondTools, if you are doing a lot of stone installations you would be best to get full wet set either hand or machine, 50 grit upwards to 10000 polish
Lithofin BOB
518
Hampshire
Test a simple ligh cleaner first that the client would use if they had to deep clean their floor, could this be a simple maintenance issue, you do not supply self cleaning floors, if you start padding this floor you will have to match the machine finish, if you even strip it you are completing works that your client may think there was an issue with your install,
Concrete guy
On limestone or other sedimentary/metamorphic stone (marble, travertine) then silicon carbide discs are probably more appropriate for cleaning and re honing or re polishing.
However if the surface is textured and you want to retain the texture then you need silicon carbide brushes otherwise discs will simply remove the texture and smooth out the tiles worked, creating another problem.
Don't do localised areas, think of it like car bodywork where repairs have to be blended into other panels. Refinish an area of tiles and try to blend into the surrounding ones if you're not doing the whole floor.
Always try a chemical solution to the problem first, mechanical cleaning/polishing is the next step if chemicals don't work.
Ttt1601
im going to pick up a left over stone from the customer this weekend, dirty it up a bit and have a play round, customer is not trying to hold this as my fault, i he has made that very clear just as i have made it very clear i am taking no responabilty for this issue, just trying to offer a bit of free after care as part of the service, anything more than a quick clean will be being charged for. cheers again gents will see how the cleaning goes and see
Reply to Limestone detiorating ? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Sticky
Hi everyone, Going through a major refurb on the house and recently had a 13mm limestone floor...
Hi Guys. Customer has one of those townhouses where the bottom floor is dug into the ground so...
Hi guys. So, I've been asked to do a bathroom for a customer but I'm not sure the best way to...
33K
We had black limestone laid in May this year. At first it looked great... It had 2 coats of...
18K
Jelthetiler
Tile Buying Popular Threads
Ttt1601
Abbotts Ann, Hampshire
Website
https://www.facebook.com/t.thompson.tiling/
Business Name
T T tiling
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
