Discuss Liquid Damp proofing Old Floor in the Canada Tile Advice area at TilersForums.com.
Drifterjoe
Hi Guys,
Ripped up some tiles on an old floor today. Some of the tiles were came up very easily and there was a very slight damp feel.
It's obviously very minor rising damp as the tiles have been down 30 odd years.
I've looked at the mapei epoxy dpm but it's pricy and only need a very small amount as the affected area is small and the damp isn't that bad.
Any advice on a cheaper alternative that I can tile over? Whatever I use I'm going to SLC over the whole floor afterwards.
Cheers
F
Flintstone
0B636C85-88BB-49C5-8891-E346B76B3C2E.jpeg I’ve used the Tilemaster dpm and it sets like rock. It’s not cheap tho, but do it once and do it right.
Bond
528
Highland
Cement based tanking systems such as sika , can be used in this situation. However if you are confident that rising damp is minor and won’t transfer or increase any, you could prime concrete with a couple of coats of SBR (moisture and salt resistant)
Coupled with a quality Slc, and tile adhesive - in such a small area, it should be fine.
Glynn
473
LEYLAND
I am not sure adding SBR to anyone's levellers is a good idea, we would not recommend it with any of our levellers. If you need a leveller, use a moisture tolerant one that is designed specifically to work with moisture as jcrtiling has said. You could tile direct to the concrete with the correct adhesive as some tile adhesives are moisture tolerant and will allow the moisture to pass through them but themselves are impervious to the moisture and the moisture will then migrate through the grout joints.
Bond
528
Highland
SBR can be used in any cement based product which will improve durability water resistance, strength and flexiability, l use it extensively for over 20 years in all situations , with only positive results. Please tell how you consider it not to be a good idea, interesting to see how you justify your claims?.
Glynn
473
LEYLAND
Does ultimate offer that @Glynn ?
Ultimate is not the one I was thinking of and has I am company support I am not suposed to advertise our products on the forum, but if you wish to contact me through our technical department I will go through it with you.
Reply to Liquid Damp proofing Old Floor in the Canada Tile Advice area at TilersForums.com
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
