Discuss lithofin fz in the British & UK Tiling Forum area at TilersForums.com.
wetdec
Here you go m8
tiler
Spud
i have been trying loads of different sealers on polished porcelain to establish which one is best here are the results i have had so far
1. fila mp90 i found this sealed the tiles well with out leaving loads of sealer on the surface that had to be buffed off finish looked great no cloudiness rating 8.5 out of 10
2 lithifin fz good sealing but didnt dry into the tile well and had to be buffed off after 20minutes finished looks good but needed elbow grease rating 7 out 10
3. sealguard tile and grout sealer rating 4 out of 10 evaporates as soon as you have got the lid off didnt really impregnate the porcelain needs several coats very expensive
4 ltp polished tile and marble sealer rating 3 out of 10 leaves a film on the tile, tiles looked cloudy after grouting needed to remove with thinners and reseal with mp 90
going to try the hg impregntor on the next polished porcelain job these are my opinions after using these sealers on my work hope this helps
redeye1979
i used the sealguard on 400x400 polished porc and it was rubbish! Never again!
TilingLogistics
When you finish trying them all give Aqua Mix a whirl:thumbsup: I use it all the time! I seal something or the other every week and I use Aqua Mix for everything. The one exception is I use LTP Antique Wax sometimes and I like Lithofin For slate provided the slate is virtually non porous:thumbsup:
Kev
F
fitzer
I normally use the lithofin for sealing porcelain - recently used the ltp and had horrendous trouble with it - wouldnt soak in - on 78yds of porcelain - never again!
One thing I always do is clean tiles before sealing as there will be a film on them from the factory - I also find the lithofin cleaning range very good too
Also some porcelain is pretty hard to clean, and if its not done right the sealers wont impregnat properly
some porcelains dont need alot of pressure to scribe them - which results in a nice clean break - practice on one piece of porcelain from the job and try different pressures until you find which one gives you the best cut
Daz
I've only had a couple of polished porcelain jobs and used the Fila grime remover and Fila Porcelain sealer both times - they seemed to work well and the results were pleasing for me and customers.
As for cutting, I used my Rubi TR-600-S with a 6mm wheel and had perfect cuts everytime. One job was 500 x 500 diagonal set, so cut bed was restrictive but I managed to get the setting out bob on so had no issues. :yes:
Reply to lithofin fz in the British & UK Tiling Forum area at TilersForums.com
Hi all, We had an outdoor limestone patio laid at the start of June (finished circa 07/06/24)...
Hi, New to the forum. Have a tiler coming in to do my floor tiles but don't think he's done a...
lithofin fz
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
