Discuss Looking at tile levelling clip systems. in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
level the floor first...
to be fair it's only the size of certain tiles that make them relevant imo. although I see plenty of photos of them being used all the time even with 300x300 tiles....I mean, really!
if you can't lay a 300 tile flat it's time to bury your trowel !
Bill
Rectified edges, 1mm joints, uneven substrates, bowed tiles, thin tiles, unequal sized tile dimensions (out of square - not all tiles the same size in the same box/range) adhesive, customer/client need for perfect joint lines - all can produce problems for lip free/joint space tiling.
leveling systems help to stop lips - I, for one, want the clips to be called lip free clips and not leveling clips.
Many moons ago, tiling was done on a thick bed of sand and cement and that meant you could create your own substrate so that your tiles were fixed lip free........also tiles were much smaller and didn't have too much bowing although they were very ambiguous with sizing.
Dave
Staff member
Subscribed
389,938
1,000,000
Co.Durham
exactly lol , these buggers are 1200 x 200 , I’ve had a chance to view a tile and they are straight, yippie 😁😁
Andy Allen
1,318
Gloucester
laid these 1200x200 without clips, they were £60 a meter but flat as a pancake, it really is all down to the quality of the tile and the substrate imo.
  • VID-20190914-WA0007.mp4
    11.5 MB
L
LM
That’s a lovely looking job Andy.
One of the advantages of clips is that they allow you to stretch the bond out also.
Now before you say “Dave”! You said you’d never use them 😁.
I’ve got a 100mtr plus of 1200mm high gloss plank tiles to do and i know in my whole honest of deep down thoughts an occasional lip will haunt me , so I’ve been thinking and i do say thinking about a lash type system 😂 , oh go on give me grief now lol.
so the laughs are over. What systems do you recommend.
How thick were the planks?
bigdave1903
483
Aberdeen
with these clips, do you need to get the same width as the grout joint or is it ok to use thinner clips along side thicker spacers? e.g. 2mm leveling clip with 4mm spacers...
Yeah thinner clips are absolutely fine. I find they tend to snap out easier if they’re smaller.
Andy Allen
1,318
Gloucester
Why would you have to use spacers if you were setting them by eye . I use 1mm clips always and if I was setting sizey tiles I wouldn't be working with joints that tight .
because alot of people on here say using spacers with clips is a must to stop the clips running the tiles out of line when you tighten them up.
Reply to Looking at tile levelling clip systems. in the Canada Tile Advice area at TilersForums.com
  • Sticky
https://www.amazon.co.uk/Leveling-System-300pcs-Spacer-Resuable/dp/B08P54N6F1/?_encoding=UTF8&pd_...
Hi I have ordered the Wunda Rapid Response underfloor heating for my kitchen. We were going...
Does anybody else have the issue of joints being opened up when using a tile levelling system...
5K
Dave
Staff member
Subscribed
Co.Durham
Business Name
David Howe Tiling.
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
