Discuss low temperature external tiling in the British & UK Tiling Forum area at TilersForums.com.
SquareEyes
Hi everyone, Hope you're all warm and well! Hoping that I can get some input on something.
I've got an external wall to tile next week, but I'm concerned about the low temperatures we're experiencing right now. I generally use Keraquick, but the tech details state that it shouldn't be used in conditions under 5degrees. Right now we're at lower than that
(London around -1) and I'm coming up empty handed with an alternative adhesive that will work at these temperatures.
Does anyone have any suggestions?
The wall is approx 7m2 - tiles are terracotta 150x150 - wall is painted.
I was thinking of scratching the wall to get some paint off, use some SBR primer and attach some wedi boards onto it (glue on the boards and then drill some washers and screws into wall to secure boards)and tank the wall. Prefer to over the top with these external situations. My reason for this is that adhesive and wedi boards adhere very well to one another. What it doesn't do is solve my low temperature issue.
Thanks in advance guys! :smilewinkgrin:
John Benton
1,138
Leeds
You'll be lucky if it goes off, I've just done a job and left some waste adhesive in the skip and it wasn't solid the next day and if frost gets into it......
It took long enough to go off in an empty unheated house, although we did have oil heaters in the room, the cold concrete floor affected setting times
Stef
Haha Robson you must have had to wait until about June then :sunny:
Ha your right JB, its normally colder in june up here though.
We have been lucky up here in Ayrshire with the weather so far, Cant believe its down to -16 in some parts of England, its normally us thats getting it sore.
John Benton
1,138
Leeds
My mum has just come back from Arrachar at the top end of Loch Lomond, and had a lovely time. At least 5 degrees warmer.
Reply to low temperature external tiling in the British & UK Tiling Forum area at TilersForums.com
    • Useful
Hi, Im looking for a recommendation for a liquid tanking. I have to use a liquid tanking...
    • Friendly
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
