F
Flosmum
Hi,
I'm a new member can you please help me?
My bathroom floor is chipboard and I've been advised to use Durabase matting to stabilse the floor to prevent the tiles and grouting from cracking etc, however, I've noticed that the floor slopes from one wall towards the door on the opposite wall by approx 8mm (the tiles are also approx 8mm thick). This will eventually create a difference in height between bathroom floor and landing floor (carpeted area) at the threshold which I think I could possibly overcome by using a wooden bar at the threshold, which will be shamfered on the landing side. My other problem is my new towel warmer is on legs so the floor needs to be level.
Do I (A) use a latex based levelling compound to even out the floor first, then use Durabase matting prior to tiling? Or (B) use the Durabase matting then the levelling compound?
Any advice would be greatly appreciated. Thanks!:hurray:
