stu-180
Nearly done my bathroom !
I have tiled all the walls and just finished the floor, all thats left is box in the pipe work, I wanted to do this last so battern onto the tiled wall and floor and then box it out and then tile it the same pattern (I think it will give a nice finish overlapping the tiles rather than butting up to cut edges and then sealing up)
I have a nice big sheet off 18 ply left and a load of wooden 2"x1" lengths, Im thinking I might make a stud frame and fix the cut ply to it and then tile this (wall pattern to follow it round) , can I use the same adhesive I used to fix the tiles to the floor ? (flexible trade rapid set)
Im guessing I will need to do a good job in building the stud frame and make sure that its seriously solid and have no flex in it if kicked of banged (likely when getting in and out of the bath).
Anyone have any helpful tips or advice ?
Couple of photos so far -
(will post a start to finish when im all done)
