Discuss Making up skirting tile in the Canada Tile Advice area at TilersForums.com.
Tony_C
528
Glasgow
Skirting tiles are generally 150mm, set your scribe cutter or wet saw guide at exactly quarter of a tile and use all 4 pieces, quick rub with a diamond pad across the top and fix lined up with floor, use red wedges at bottom to keep alligned then slip trim in, mitre external corners butt up internal and mitre all corners of trim.. As above Silicon joint from skirt to floor..
This :handpointup:
Reply to Making up skirting tile in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
I want to tile the bathroom myself, two walls and inside the windows - seen some really nice...
Hello all I’ve purchased some Wickes Mississippi grey 300 X 600 Matt porcelain tiles for wetroom...
Worcester
What member type are you?
  1. Professional Wall and Floor Tiler
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
