Discuss Manual Cutting Method for socket/outlets in middle of ceramic tiles? in the DIY Tiling Forum area at TilersForums.com.
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits) then using a hand saw with tungsten blade to cut the required piece out.
Would this work okay?
I don't think using a wet saw, which I do have to do this would feel comfortable and using a manual saw you can easily stop or correct yourself as you go without wrecking a tile.
Plunge cuts with 100mm grinder using dry blade
Reply to Manual Cutting Method for socket/outlets in middle of ceramic tiles? in the DIY Tiling Forum area at TilersForums.com
I have some projects on my hand. Therefore, I want to know exactly what type of drill bit will...
Hi all, I’m using split face tiles (10mm ceramic 600x300mm) on one wall and I’m failing to cut...
7K
Time's Ran Out
Hi guys, its my first post on there though have been gaining useful tips for a while so thanks...
    • Informative
    • Useful
I used to work in a tile shop in the the 1980s and we were given an ultrasound tile cutter to...
7K
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Tilers Forums on FB
