Tiling Tool Suppliers
Discuss Manual tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Daz
Hi Ross,
I use a Rubi TR600-S for straight cuts. The only thing I have struggled to get a good straight cut on is fully vitrified tiles, only my wet cutter will go through those suckers.
For internal corners or shapes I use a combination of wet cutter and nippers (ceramic only for nippers).
Hope this helps,
Regards
ross lewiss
so if i buy a ts70 plus and i need to cut a piece of tile that the breaker wont cut due to the fixed breaker, then i have to use a wet saw? more expense arrgh
i only want to concentrate on ceramic and porcelain because i cant afford to buy all the equipment for the other kind of tiling and i thought a rubi tile cutter would cut any porcelain or so the video clip shows?
H
Holohana
Then its the Tx or TR range of rubi your after, moveable breaker.
Daz
My TR600-S doesn't have a fixed breaker so I can make straight cuts anywhere on a tile. Within reason, as it doesn't play nicely when trying to just take a small amount off! But no dry cutter will allow you to do internal corners or shapes unless you want to score with a dry cutter and then nip the sucker out (horrible if trying to do it with porcelain or vitrified!).
sWe
I've tried Rubi cutters, but I didn't really like them. I used Sigmas until fairly recently, when I switched to Montolit, which in my opinion are among the best cutters you can get.
Without really trying, I can cut slivers just a little over 1cm wide, out of 10mm thick 33x33cm (larger than that is rare over here) Porcellanato, which is the densest, hardest grade of porcelain.
ross lewiss
thanks swe
i am gonna look at montolit. rubi seem to be really big but theres too much choice??? i realise that i wont be able to get away with just one cutter but montolit and sigma and husqvarna seem to narrow the choice down so it makes it easier for a lamen like me. what 2 montolites would you suggest. when i finish my course i will concentrate on kitchens and bathroom and small floors.
thanks, ross
sWe
First you need to decide wether you want a push or a pull cutter. In my experience, pull cutters are faster to work with, but push cutters are easier on the wrist.
My old main cutter was a pull-Sigma, and part of the reason I switched cutter was that it was a bit hard on the wrist. I also wanted something different.
So I went and bought myself a Montolit MasterPiuma 63P2. It covers 90% of my cutting needs. Next time I get a job with lots of small tiles though, I'll get myself a MiniPiuma PB, as the MasterPiuma is a bit bulky and heavy.
ross lewiss
http://www.youtube.com/watch?v=yigAjKmquIY
just found this on youtube and it shows the sigma you mentioned, couldnt find one on montolit but loads about rubi. your right, the pull motion looks the most natural although some people on here say they are difficult to get used to. its a minefield for a learner arrrgh
sWe
Videos of Montolit's main cutters:
MasterPiuma P2
MasterPiuma T2
MiniPiuma PB
MiniPiuma TB
The pull motion has a more pronounced feeling of control than the push motion imho, but I've used pull cutters for most of the time I've been a tiler, so it's probably just that I'm still more used to pull cutters than I am to push cutters.
The push motion is more ergonomical than the pull motion, as you don't have to twist you wrist.
It's mostly a matter of what you're used to.
Reply to Manual tile cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
1200mm Manual Tile Cutter for around £100 Topway Tile Cutter 1200mm / 1000mm - Porcelain...
Admin1
Hi everyone! I'm looking to purchase tile saws to handle large format tile up to 48". How many...
Hi everyone, as tiles are getting bigger and bigger I'm looking for a new cutter. Now my...
Hello. I’m about to do a patio around a pool outside. I’ve been looking at manual scribe and...
Hi Peeps, I'm new to this site but been in the game a looooong time :) Looking to purchase a new...
Popular Tile Cutter Threads
Manual tile cutter
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
