Discuss Mapei adhesive - Mixing! in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
For anyone that is new to using Mapei adehesives, just a small word of caution regarding mixing instructions. The instructions on the bags of grey Keraflex Maxi and Keraquick regarding water quantities are incorrect. Always check out the Mapei Data Sheets for the correct quantities otherwise the mix is soooo thick!!!!
grumpygrouter
I mix to the desired consistency that i like to work with.....:thumbsup:
So do I Dave but when I use an adhesive for the first time I always try to mix per instructions to see how it should be according to the manufacturer and adjust to my own "taste". In Mapie's case the instructions on the bag are not the same as the data sheets. Just thought it would be good to let peeps know!
Having said that, I find the Keraflex Maxi if mixed as per the data sheet quantities is spot on. :thumbsup:
beanz
Berkshire
I know when Darren (at NETT) showed us the pci nanolite addy, it was really light, and he had no slippage at all with a 400x400 stone tile, but wasn't sure if i should expect the same grip with every spf, as a bathromm fitter i know refuses to use it on walls as there's too much slippage!?! Thought maybe he's mixing it too wet as well lol!
Maybe i should start using my mixer.. I've got kinda used to mixing everything by hand, but i'm thinking maybe that's the reason i'm not getting it stiff enough. It feels stiff when i'm mixing it, but once i start troweling, i realise it's not that stiff at all!?! :lol:
White Room
It's an age thing:lol:
Reply to Mapei adhesive - Mixing! in the British & UK Tiling Forum area at TilersForums.com
Hi guys Is anyone on this forum familiar with Mapei Pro Standard tile adhesive from Tile Giant...
7K
Ian Mead
I
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
First job with this type of stone (have laid floor and wall tiles several times successfully)...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
