Discuss Mapei Keraquick Grey Storage life in the UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,089
1,323
Staffordshire, UK
Possibly but I wouldn't like to guarantee it. I'd give Mapei Tech a quick call and ask them 0121 508 69 70
It's normally more to do with how they've been stored and what temperatures the bags have suffered etc than actual going off dates. Or so I'm lead to believe.
Rolandk
Thanks Dan,
as you suggested I spoke to Mapei Tech and they say that in perfect conditions like their warehouse which is kept at 19 degrees 24/7 it would probably be OK. So over winter in my dry but unheated garage not ideal!! iThey suggest checking a bag to make sure it's still powder and not gone hard or got lumps in it then mix some and test. It might be OK but may have lost it's fast set characteristics and could take 6-8 hrs. to set. If it doesn't set it's obviously knackered!
Cheers,
Roland
bugs183
If you already doubt it, will you trust it???
How will you know it's ok without tiling the floor? Then you find out it's duff and you have to pull it up as you won't trust it.
I'd bin it, rapid set that is getting old is awful to use as different mixes will dry at different rates.
Bit of a shame, but is it worth the worry??
Rolandk
Hi,
thanks for the responses.
Earlier I opened a bag and it seemed fine in the sense that it was loose powder with a few soft lumps that were easily broken up when mixing. I mixed a little up and it seemed to go off in about 3 hours and a tile I stuck to an old concrete slab was stuck fast after that time. So it seems OK but should I be worried about those few soft lumps? Can't remember if you always get those?
Cheers,
Roland
Reply to Mapei Keraquick Grey Storage life in the UK Tiling Forum area at TilersForums.com
Our annual poll has been requested and is quite late in comparison to when we usually run it...
44K
On one
U
I'm wondering if anyone can give me some advice on which grey grout to use. I have a 100mm x...
32K
Pallet Deals - Adhesive & Grout Keraquick Grey 20kg Pallet Deal- 48 Bags - Pallet Deals -...
6K
All I needed was half an egg cup of Weber Joint pro Jasmine grout. After asking if there were...
J Sid
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
