JLM Tiling
Hi guys, hope everybody is doing good, just wanted to run this past you to see if anyone else has had any similar problems.
Basically I've started subbing for the local top supplier Channel Islands Ceramics, great number this, get to do lovely jobs and they pay well, plus there is a bit of status attached to working for the best in the island! Not that 'civvies' would understand!! Anyway they insist on supplying the adhesive for the jobs they give you. You buy it from them basically. They only supply Mapei gear which i was wanting to try out anyway as everyone on here seems to rate it. Previously I'd been using Ardex. Anyways the job is 300x300 vitrifies porcelain fixing onto wedi. When I first started I found that it just wasn't grabbing quick enough so had to quickly fix battens up. This kept being a problem so last night when I finished I left all the spacers in. Just got back in here today and was taking a spacer out and the tile came with it!! Let's face it, that's not ideal!! Got my scraper out and the gear just rubbed away, was still soft. Now this is at least 24 hours later. What do you guys think? Is this a big problem like a batch fault or is it just the way Mapei p9 is? Should I worry or should I just get on with it and be more careful with the spacers? As for bedding in the tile I give it some force so it's definitely got good contact and you could see the muck had been squashed down nicely. No gear at all was stuck on the back of the tile, came off clean
