Discuss Mapei Primer G in the British & UK Tiling Forum area at TilersForums.com.
davphi338
I've tried to scrape off as much lino backing as possible but some of its just doesn't want to budge. I've used an industrial hot air gun and and even tried boiling hot water onto it to try and soften the adhesive but its still difficult to budge. Its as if there is waterproof paper stuck to the floor. Its obviously the final layer on the lino backing. If boiling water doesn't shift it then I'm starting to think that it should be OK to tiles over once primed.
DHTiling
You need to remove it.......
Try one of these attachments for a grinder..
Cupped Diamond Wheel
Fits standard type 115 mm angle grinders (100 mm x 22.2mm bore.)
Ideal for grinding away bumps in uneven concrete floors and keying old tiles or terrazzo before tiling
click picture to enlarge
weight 275g
Price: £18.88 £21.71 Including VAT at 15%
Wire Brush for Angle Grinder
A very aggressive wire brush for use in an angle grinder - You will be amazed how fast this works!
Use to remove all kinds of unwanted paint, adhesive, rust and other surface contaminants etc
Very good for 'keying' smooth surfaces.
- Hardend & twisted 0.5 mm steel strands
- 75 mm Diameter
- Standard M14 thread (fits all standard angle grinders)
- Max speed 12,500 Rpm
We recommend you wear suitable eye protection overalls and gloves while using this tool
Price: £4.49 £5.16 Including VAT at 15%
Both available from trade tiler.
Then you can prime and tile...some comps say don't mix primers but then an acrylic primer is a primer...
CJ CERAMICS
was in CTD today buying tiles for a customers wet room and had the same discussion with the guys in there( not me but another customer i was just eavesdropping) anyway the lads in there said that mapei adesilex p9 is perfect for concrete floor and has a built in primer? im not sure about this would love to know your feelings for future ref. cheers chris
CJ CERAMICS
P9 has a built in primer........:lol:...great advice NOT......
Ask them why does a gypsum substrate needed priming with P9 if it's built in..:smilewinkgrin:
Not all concrete floors need priming but priming can reduce the suction rate of the moisture and give more open time for adjustment...
cheers dave :thumbsup::thumbsup::thumbsup:
Reply to Mapei Primer G in the British & UK Tiling Forum area at TilersForums.com
Hi - I'm laying hardiebacker on top of green chipboard. I have a load of Mapei Primer G left...
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
https://www.tilersforums.com/threads/tiling-on-mapei-renovation-screed.91864/post-964717 Hi...
Mapei Primer G
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
