ross9807
Help!
I am having trouble with MAPEI Ultracolor Plus but only with jasmine.
i dont have a lot of experience but i've grouted with biege from the same company and had no problems.
But with jasmine...... i grouted an area and after it was patchy and some areas were white, infact most of it was white. So i called mapei they said that i had started too early sponging it down or maybe used too much water. -both sound about right.
(this part was actually with keracolor ff)
i thought this was cos of keracolor so i started using ultracolor plus, but this time i measeured it exactly and waited quite a while and put minimum water on to wash it off. and i got the same **** maybe not as white.
then i rang mapei again, i thought i had followed all the rules exactly (measure-mix-wait-mix etc) but the bloke told me, that its because i'm mixing it by hand. and i need to use a paddle. -i was taught that this isnt really needed. especally for a couple of m2.
I have read the other thread about a bloke who had exactly the same problem. and in the end he got it so so looking.
But were there any conclusions? is jasmine just a sensitive grout???
Now my biggest problem is how to put it right,
fuga fresca was suggested, but the bloke from mapei told me i have to all the edges of every tile. is this true?
also does anyone have any tips for using it?? and do u think it will work??
Thanks,
Ross
ps. also how do you know when to give it that first rub over? finger test? or is that for the polishing?
pps. i've just discovered this site and i can't believe how good it is.....
be prepared to have a weekly question
Thanks,
Ross
