Tubsy
hi all first ever post on here but i need advice regarding a job were on,
scenario : preparing a wetroom floor and tanking walls in shower area customer has her own builder applying the marble slab to the walls,
slabs are 20mm thick and 1800mm x 1200mm,:yikes🙁very big walls solid brick) the original background was lath and lime plaster daub. this has been removed and i suggested wedi board dabbed and doweled onto the brickwork as i believe this is probably the strongest bond available i also suggested they mechanically fix the slabs with pegs and wire
, thursday got to the job and the builder has screwed marine ply to the brick work at 600mm centres so about 8 fixings in each board:mad2:.he swears blind that this will be sufficient to hold the weight and wouldn't trust wedi boards, so tommorrow i'm going to tell the customer i don't think this guy is doing the job correctly and raise my concerns!:ninja: all i want to know if anyone on here has had to fit marble of this size and am i correct with my recommendations
