Discuss Marble with brown stains in the British & UK Tiling Forum area at TilersForums.com.
hmmm I thought i had read somewhere that sealing the underside and sides actually assisted adhesion
why wouldn't you seal a damp tile with a sealer as long as it was water based and breathable?
tel
tel
Aqua mix water based sealer says you need to wait 48hrs after grouting to apply sealer. So even using waterbased sealers you have to wait.
The product I had in mind when I asked the question was Lithofin Stain Stop (the water based version of course).
Thinking about it now, If you paint over plaster that has a few damp areas with a water based paint like a vinyl matt emulsion if reacts differently and is clearly visable where it doesn't soak into the plaster but rather sits on the top. You would think that it might just be slightly diluted in that area but becuase the area is already damp the product is not drawn in to the surface so it does not bond as well - I suppose the same could be said for a sealer
breathable ,does that mean it allows air to pass through but not moisture , id reko leave 48 hours as above :8:
Reply to Marble with brown stains in the British & UK Tiling Forum area at TilersForums.com
