Discuss marcrist porcelain blades in the British & UK Tiling Forum area at TilersForums.com.
I've been using my new D24000 with the standard DeWalt porcelain blade in this week to cut Keope full bodied porcelain.
After day one no probs, although I had noticed corners snipping off the triangles I was cutting, but as I didn't need the corners it didn't bother me. This happened to two out of three cuts.:thumbsdown:
Yesterday I gave up trying to cut these tiles with my DeWalt D24000 as even the straight cuts were sheering off half way through:mad2:as even my TS40+ wouldn't cut these tiles....
I, unfortunately, had to resort to using my grinder and Marcrist CK850 dry cutting wheel, which I must say has flown through these tiles with great ease:thumbsup:
I am now considering getting an upgrade to the DeWalt blade although I'm sure it will cut lesser quality porcelain and stone just fine, I want a blade that will cover all bases:thumbsup:
Please note this is not a disparaging report of the D24000, more a critique of the density of the Keope tile:thumbsup:
grumpygrouter
:lol:When you've just spent thick end of £700quids on a machine, you blame the tiles:lol::builder2:
I've fixed these Keope tiles a few times and it is "definately the tiles"!! the riven finish makes it virtually impossible to get a good dry cut so a good blade for the wet cutter is the way. I used a Marcrist on my Rubi DW 250 and it cut them fine but the blade drifts and pings the corner off!!!
Kev did you get two blades? if so have you tried the one with the little question mark grooves? I find this better for pocelain
Aye mate, it's the question mark blade I'm using:thumbsup:I thought both the blades were the same.
Honestly these tiles are probably the hardest porcelain I've ever come across:yikes: Bell metal springs to mind....:incazzato:
They were just sheering off half way through a straight cut and I was going ridiculously slow:thumbsdown:The TS40+ wouldn't touch them:thumbsdown:
Ended doing all the cuts with my grinder, CK850 blade and a steel straight edge, no probs at all:thumbsup:
Reply to marcrist porcelain blades in the British & UK Tiling Forum area at TilersForums.com
1200mm Manual Tile Cutter for around £100 Topway Tile Cutter 1200mm / 1000mm - Porcelain...
Admin1
Sigma or Rubi Tile Cutter? What is you experience with either, or even lucky enough to have both...
Paul Smith
We had a wet room fitted by a large company. We have issues with a few large steps where the...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
