Discuss Marginally high CPC end to end readings Electrical Advice in the Electrical Advice area at TilersForums.com.
Marginally high CPC end to end readings Discussion ThreadMarginally high CPC end to end readings Electrical Advice
Sure this has come up before but yesterday testing after adding a spur and end to end readings on CPC come out about 0.2ohm over expected reading (was expecting about 1ohm from LL & NN (0.65)
Checked all sockets I could see (some were very old so suspect the sockets themselves might be a contributing factor) other possibility is JB under floor.
Question is would you just report this on meiw, start ripping up floorboards, recommend FI or what?
Earthing system was TT. Zs - 9.75ohms
Also there was quite a bit of original stranded copper in the circuit.
Marginally high CPC end to end readings for the original thread on Electricians Forums
Reply to Marginally high CPC end to end readings Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
