Discuss marking cuts on floor tiles in the Best Floor Tiles area at TilersForums.com.
K
kev richy
When Tiling A Floor I Have Been Using The Method Of 2 Tiles On Top Of A Fixed One ;too Mark My Cuts.i Find This Accurate But It Means That The Edge I Have Cut Is In The Main Field Of Tiles.is This Ok Or Am I Doing Something Wrong.iwould Like Too Have The Machine Cut Edge In Main Field.i Can Do This By Measuring But It Seems Slower That Way.how Do You Professionals Do It? Also Is It Correct Too Leave 6mm Gap Around Room?
GazTech
I would place tile to be cut on top of fixed one face up....push it toward the wall parallel to the fixed tile by 7mm by eye......then place another on top against the wall (to be cut against) and mark the tile to be cut off the back edge of it....If the angle is quite fierce or tapered,then use an off cut about an inch wide, the full length of a tile and simply mark your tile at both ends....it's quicer than with a tape and very accurate....Gaz
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping some threads in the tiling forum, don't worry if it isn't current discussion, just ignore the thread and it'll drop off the list quickly. If you do wish to reply to it, go ahead, that's fine too. Your input might be valuable and help a tiler out in the future.
stephenoneill
For tiles up to 30 cm I hold them against the substrate and mark .and for tiles over 30 I use tape measure
Reply to marking cuts on floor tiles in the Best Floor Tiles area at TilersForums.com
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
gamer1
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
