Discuss marmox boards in the Canada Tile Advice area at TilersForums.com.
I fixed marmox bards in bathroom with view to fitting large tiles 20cms x 75cms tiles.
I fixed the boards with Mapei Adesilex P9 and would like to know if this would hold the boards when the tiles get fixed. I now know that I should have used flexible tile adhesive .
I did fix as recommend with screws and washers and then used hardie backer board PU adhesive aswell.
would all this hold the large tiles to be fixed to the marmox boards ( I will use flexible adhesive on the wall tiles
cheers
pete
Reply to marmox boards in the Canada Tile Advice area at TilersForums.com
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
  • Sticky
  • Question
