TilingVirgin
I'm installing UFH. Current scenario:
- 9mm WPB Ply screwed down @ 150mm centres onto wooden floorboards
- 10mm Marmox insulation boards (1250 x 600mm)
- UFH cable
- Tiles
Question is for installation of the Marmox onto the ply. Would you use tiling adhesive (Granfix flexible rapidset 3mm bed) with screw in each corner? Or can I just screw down insulation boards @ 300mm centres and forget about the hassle of adhesive? Marmox website suggests either option.
For the adhesive option, does the ply need to be primed? If so, is PVA glue/water mix ok?
- UFH cable
- Tiles
