Discuss Plywood or Chipboard under Backerboard? in the America Tile Forum area at TilersForums.com.
Hi all,
Quick question, when installing 6mm backer board onto a floor prior to tiling, would you prefer plywood or chipboard underneath?
Also, do you use adhesive and screws to fix the backer board down, or just screws?
For reference, it would be 22mm thick either way, and if chipboard it would be the P5 moisture resistant stuff. If plywood, it would be sealed properly with SBR before installing backer board. Suspended timber floor underneath.
Reply to Plywood or Chipboard under Backerboard? in the America Tile Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
