me again.plaster board & bathrooms
K
kickinside
Hi all,
well i WAS hot on the trail of dot and dab plasterboard to the walls and tile away having cleaned the walls back to bare brick...
I have now been advised on no account to use plasterboard anywhere in a bathroom - that i should be using waterproof plasterboard at the least, preferably aquaboard -problem is as far as i can see they cant be dot & dabbed so that means stud work....and for 10mm poc tiles thats goign to mean 2"*2" (walls area bit out as well..)
The problem with this is that if i put stud work in all the baths/showers etc wont fit!
OOPS....
What say you guys to this sage advice ( the shower is a sealed 'shower cabin' so not in contact with the walls, bath will be bath only (no shower)
No one was mentioning this on her so i guess it may be BS im being told?
I do know BG say the MR boards have to be pva'd before skimming:smilewinkgrin:
that does surprise me as a couple of years ago I'd sbr'ed some in preparation for some 10 x 8 ceramics, and the tubbed gear that I was using took an age to set, BG said that I shouldn't have primed them 'cos it wouldn't soak in and just sit on the surface.
Doug, thank you very much for taking the time!
7 days is a bit of a pain though i was hoping to board and tile this weekend....wonder if thats MR specific - as others have said a matter of hours normally if you use adhesive for 'normal' board...i guess they may just be covering themselves good and proper as well.....
anyway many many thanks for taking the time!
It depends what you use this would take the weight after 24 hours Pete
PCI Nanolight® Rapid
Bathroom Tiling Advice
Unsolved
kickinside,
Perry,
kickinside,
Perry,
