Metabo Asr 35 M Class Dust Extractor
  • Thread starter Thread starter lizzardtong
  • Start date Start date
  • Tags Tags
    dust
When you lift the lid it looks identical to the bosch gas 50 even the same hepa filters, keep,using the cyclone pre seperator it really does reduce the dust levels even with such a good vacuum
Was considering bosch was cheaper but it uses old system for cleaning filters which is blast of air every 15 or 30 sec. In metabo you got sensor that switches cleaning when its needed
This is quite convincing
View: https://m.youtube.com/watch?v=0LUropm7tIU
The bosch has vibrators that hit the filters it's a manual system I bought spare filters and rotate them every so often ,they aren't cheap though
Not cheap but you get what you pay for. And you can see a difference when you deal with fine dust.
Just watched the video that's why I keep spare filters once you use it as a wet vac with the filters in it badly effects the dust extraction if the filters get wet/ damp even with automatic cleaning system it won't work at it best if the filters get wet
Tags Tags
dust
lizzardtong,
Spud,
lizzardtong,
Spud,
