Discuss Microflex Mixing Ratio... in the British & UK Tiling Forum area at TilersForums.com.
matt_sx
I'm a DIY'er :grin:
Hi guys, I know your sharing your trade but was wondering what you think of the 4 to 1 by weight with this grout?
I've just mixed up 2kg of powder with 500g of water and I struggled with it :mad2:
Just wondering if you add more water? or it's mean't to be more stiff than eerrmm??? toothpaste!
Grouting SUCKS!! :lol:
Many Thanks
Matt
grumpygrouter
I think you will probably find that most of the pros on here don't "measure" the mix any more. they add powder to water and mix, adding more powder until they acheive the consistancy they want.
Toothpaste isn't really that thick is it. Mine isn't!
Did you do it by hand or use a mixer in a drill. I can imagaine by hand it would be quite heavy work. A drill and whisk makes it much easier. Also did you add powder to water or water to powder?
matt_sx
Bit hard to explain but i'll give it a go, I did mix by hand purely because the instructions said if mixing mechanically to keep the speed low
I've used a different brand of grout and mixed with my drill and really stirred it up but had problems with it going off within 10 mins!, not sure if it was a dodgy batch? ****e grout? or what? so thought i'd mix this by hand
As for the problems I guess it's down to me and my speed , but it seemed too dry, and when using a piece of plastic waste pipe to force it into the joints it wasnt smooth , but parted in places? looked ok when I sponged over, but now thinking I've wiped out too much grout :huh2:
It's not easy and maybe i'm too anal, but was wondering if you pro's add a little more water
grumpygrouter
I find grouting a bit of a black art to be honest. When mixing, you need to aim for the constancy of soft whipped cream, sort oflike when it comes to peaks that don't collapse. A good test is to see how easily it falls of the float. I find it should just about slide off. if it is runny it is no good and if it sticks to the float it is too thick. Practise, as always makes perfect. You just need to take your time. Always add powder to water, a bit at a time, and not the other way round.:thumbsup:
matt_sx
always mix bit by bit cause if you mix it all up and it ends up to runny.........no good to anyone, unless you live two seconds from the tile store so you can quickly get another bag....
Thanks mate, makes complete sense!
I love tiling, and with a 5 hr pot life with adhesive I can take my time, never thought grouting was going to be the problem!
Respect
Matt
matt_sx
Hi Matt,
I'm still quite new to tiling and whilst I don't measure my addy any more I do still weigh out the grout. I've found that the 4:1 ratio for microflex with just a dash more water works for me. It's still quite stiff but you can really force it into the joints with the float and it doesn't pull out.
Mark
Thanks Mark
You guys will probably laugh but the wall I grouted today was only 4m2!! and I sweated like a pig!!!
I've got 2 more walls to do but theres a window in one and a door in the other so a little smaller
For a trade that sounds so easy I'm now a little wiser :thumbsup:
Thanks for the replys guys
Matt
robbo
Thanks Mark
Matt
The worst rooms to grout are rooms with not a lot of ventilation, i did a regrout the other week and the sweat was poring off me!!!:whatchutalkingabout
CJ
1,088
Somerset
I always mix up small amounts at a time............4-5m walls at a time. Like has been said......bit like whipped cream or a Mr whippy :grin:
Small amount of water in the bucket to start...........add powder and then mix, adjusting as you mix.
You mix Microflex right........its nice to use...........get it wrong its a *****:whatchutalkingabout
matt_sx
couple of pics of my bathroom
still got to buff the tiles on that wall, but also got to get the confidence to grout the other two!!
Reply to Microflex Mixing Ratio... in the British & UK Tiling Forum area at TilersForums.com
So... have a problem maybe some of you guys (and girls) might be able to help with. Laid a new...
19K
Hi all, I've been reading all your helpful advice to everyone, so after tearing my hair out...
25K
Ok so on the bag it States: 17-18% parts water per 100 parts by weight of Screed, As its my...
6K
DHTiling
Hi, I'm a neewbie to the forum and although not a complete professional I have been...
6K
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
