Discuss Mixing powdered adhesive in the British & UK Tiling Forum area at TilersForums.com.
F
Fekin
Tip, if your mixing a whole bag at a time using a propper marked out mixing bucket that is marked for the amounts of water to use for that make of adhesive, or grout, then fill to around the 3/4 mark of the recommended amount of water only, then add the bad of powder, then mix and add little amounts of water to suit your working conditions.
That way if you need\want the adhesive\grout that little bit thicker then you have the option there, where as adding the full amount of water from the off set leave you no room for variation.
grumpygrouter
What about you previous post then Feks?
Reply to Mixing powdered adhesive in the British & UK Tiling Forum area at TilersForums.com
    • Agree
    • Informative
Is the issue with ready mixed adhesive seemingly only recommended for 30x30 tiles max that it...
    • Friendly
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
I'm having a nightmare trying to establish product info from distributors. For example...
Hi all what adhesive would you recommend for dot and dabbing foam cored backer board onto...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
