Discuss Mixing in the British & UK Tiling Forum area at TilersForums.com.
jimbob
Just wondering what people do when they have to mix a second batch of adhesive. Is it necessary to completely clean the bucket prior to mixing the new batch, or will a quick scrape round the bottom with a bucket trowel suffice prior to the new stuff going in?
Also for grouting, does the bucket need to be spotless for each new batch of grout??
Cheers :thumbsup::thumbsup:
diamondtiling
Spotless is best for grout at all times, when I do an adhesive mix I always clean the bucket out properly, this helps to stop any contamination from different batched adhesives and if you read the bag they always specify a clean bucket. I have had my big mixing buckets for years and they look as good as new, same as my drill whisk, it's as as good as new, its cleaned after every mix and soaked in concrete cleaner every month or so.
davy_G
I clean the bucket out well, make sure there is nothing in the bottom rim going off.
Tend to use the smae bucket for a month or so but wooner or later i mix too much and end up ditching the bucket with the extra to save cleaning it up.
I have a couple of stacks of used tubbed gear at home and just lift a spanking clean one. I clean them out when finished like new.
I also lift big old paint buckets, 18 inch tall, and store my mixer paddle in it inbetween mixes, put a couple of small stones, 2/3 full of water and a 30 second blast on full and its a clean as a whistle for the next mix. Get a fair build up of sediment over the day in the bottom, but again a quick blast before tipping it out and it all runs out. No bother:thumbsup:
Reply to Mixing in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Morning all, a few tips would be appreciated here please - I am just completing a few jobs for...
6K
WetSaw
Mixing
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
