F
Fireburst
Hi,
I am currently putting a new tile floor down in the kitchen of a house I recently purchased. I purchased the tiles from Topps Tiles and was originally going to lay the tiles with a 5mm grout line.
The instructions that came with the tiles said a 2-3mm grout line must be used for the best ascetic effect. I laid the pattern out (3mm) dry and although there seemed to be a small deviation in gap size on the single repeat it did state that there can be small deviations in the tiles. Roll forward 4 hours and I have laid 1/3 of the kitchen floor and its all going very wrong. The tile set comprises of 4 different sizes and its the smallest tile that is giving issues. Even touching the surrounding tiles, it still needs more space which pushes the grout line wider.
I stopped at this point as it was getting late and I thought things would look better after some sleep and a reevaluation of the situation.
In the morning when going over my work it struck me they would have to be lifted and I would need to start again.
I have looked at the small tile and notice that if I put 3 together touching they are a few mm wider than the large tile. Surely this isn't correct? I understand that by the very nature of pre packed modular tiles that have to suit a number of patterns you are going to get some small differences in the gap but logic would dictate that the smaller tiles should be ... well a little smaller to allow for grouting?
I have made a complaint to Topps Tiles and they think they are fit for purpose but I though I would like the views of some professional tilers if possible?
