Discuss Moisture Meter in the Canada Tile Advice area at TilersForums.com.
I offered £60 and we met at £65 plus £5 p&p off this seller a couple of weeks ago
the answer is they are all different Raff and depending on what test you want to do you need different equipment for each , there is a digitial electronic meter from Tramex called a concrete moisture encounter meter this elecetronically tests the amount of water in the test sample non destructive , then there is a hygrometer which can be destructive or non destructive depending on how you test the area and you can do a calcium carbide reagent test which is a destructive test where by you take a sample crush it up put it in a reaction vessel with a reagent powder and the amount of gas produced in the vessel relates to the amount of water in the sample so the answer is it depends on what you are testing for and how accurate you need to be
Reply to Moisture Meter in the Canada Tile Advice area at TilersForums.com
