Monolit P5 tile cutter - set up help
Just a DIY guy here. Purchased a Monolit P5 tile cutter and I’m impressed….probably sell my wet saw. The tool comes without any instruction guide and there really isn’t too much that needs set up. There are online demo videos which are helpful as far as tool capabilities and versatility.
The tool has a fold away guide for lining up a cut to any angle you set it for. Mostly I use it for 90 degree cuts. The tool can cut up to a 50” tile so the main bar holding the cutter is long. My issue is that it’s difficult to set the stops to have it at 90 degrees. Does anyone have some advice on an easy way to set this accurately each and every time. I’ve had to resort to trial cuts until I get it perfect.
Tags Tags
None
JLLove,
JLLove,
