Guest viewing limit reached
Buying a manual tile cutter, Sigma or Montolit?
I changed from Rubi to sigma some 3/4 yrs ago, can’t fault them.
Simple straightforward machines which are bullet proof.
And still hand made in Italy.
Unlike most every other machine out there, which is now made in the Far East.
And cutting wheels simply just don’t wear out.
And they come in sizes all the way up to 2.4m
Images show the 2.4m up against the 4e4m.
1200 x 1200 x 6mm
Cant seem to find a seller that have the 3C3M in stock here and I cant find Rubi what so ever here in sweden. So it would probably come down to the 3C2 or the 63P3.
Get it straight from the Italians online then 😎
1200 x 1200 x 6mm
Those are HUGE 😀 They sure look like quality. Got the same sense in the store.
Yeah, that would be an option but I would like to start tiling on monday.
Btw, is the only difference on the 3C2 and 3C3M the handle? Would you be able to change the handle later on and convert it? Might be somewhat wasteful though. I imagen the handles not being that cheap.
Yes you can change the handle no problem. It's around £70 ish to buy the handle alone though.
If you feel you would prefer a push but by monday then maybe Monti is the way forward
They are very good quality, so bulletproof in fact, that they don’t even make cases for machines over 75cm cutting length I believe it is.
Yes on these models the bar is 10mm thick and all 10mm handles are interchangeable. That is what I do with my machines, some of them I have 3 handles so I can change depending on the task.
Hello! I am new here but I have been reading a lot about manual tile cutters on the forum. I am looking to get a quality tile cutter that will last a long time. I already have a wet saw and are looking for a manual tile cutter that can handle 400mm/16" tiles. My budget is around 350$.
I am far from a professional user but I enjoy working with good tools that I can grow and learn with. I like the "Buy Once, Cry Once" motto instead of buying something cheap you will end up being frustrated at every time you use it.
From what I can gather the two brands that seems to be coming up a lot is Sigma and Montolit. So I have looked at a few of those models. It seems that you "cant go wrong" with either but I still like to have your opinion before I decide.
I have a nearby store that sells the SIGMA 3C2 and the MONTOLIT MP 63P3 for the same price (320€ or 350$ or 290£) and I have been looking at those.
View attachment 110004View attachment 110003
I went to the store last light but I only had 5 minutes to check them out before I had to go so I only got a quick look at the two versions. And the store is the kind of store that do not let you try them out...
My quick impressions were that both tools seemed to be quality tools with a little bit of a different design "flavor".
I got the impression that the Montolit had more features and special mechanisms that looked really good but maybe a bit over-engineered (simple is good). And that the Sigma had a bit fewer mechanisms/functions but seemed like more of a "no nonsense machine" that just do the things that you "actually need" really good.
After the few minutes I had to check them out I felt that Montolit was a bit better than the sigma. But since I could not try them out in the store I ended up doing some research here on the forum. And how the tool look like is not nearly as important as to how they feel and perform in real life scenarios. Therefore I am here, asking you guys that have first hand experience with the tools what you would buy if you would chose of these two. Or if you would chose a completely different make or model.
I saw some video of the MAX series also (
) With push and same type of "swing up tile splitter" with plastic on as the Montolit P3? The one I checked out at the store was the TRACTION pull variant and they did not seem to have the MAX-series.
I also saw this post about the Montolit having an issue with diagonal cutting but I did not quite understand this or if it has been fixed in a revision? If anyone could explain that would be very helpful. Montolit - Sigma vs Montolit - https://www.tilersforums.com/threads/sigma-vs-montolit.81271/post-834077
Which one would you get of the two? Or would you get another model or maybe another brand?
Thanks!
Awesome brownie points from me for this thread mate. It had a picture in it, a link, a poll and a video.
Been trying to get these bar-stewards do all them for years lol
Sorry i meant to answer that also outwith cost of handle previously. same but with the max handle reduces it to a 725mm cutter
Brodholm,
LM,
Brodholm,
LM,
