Guest viewing is limited
More pricing help! Travertine Mosaic....
GazLC81
Hello again, I need yet more help!
I have another estimate to do for something I haven't done so far.
It's kitchen walls about 4m2 and it is to be done in 5cm Travertine mosaics. Most of the wall will be tiled onto exsisting ceramic tiles. I have done mosaic but they were ceramic and I REALLY underquoted so fearful of doing it again.
I don't have a clue where to start other then use a white adhesive to stop staining and that I need to seal the tiles and wet cut only.
How much do i charge for sealing/when do i do it?
Is Whitestar ok?
What would you charge?
Thanks AGAIN!
Gaz
Sorry to bump the thread but i could do with some advice as I need to do the quote for her by tomorrow.
Cheers
Gaz
I think you should be looking about £200.... especially since you are going tile on tile with mosaics which need wet cutting... that is a bit slow.
Probably charge near trade price for the materials though.
So can I just use a tub adhesive? I was going to use whitestar is that ok to use?
Do I fix tiles to wall and then seal or do I seal before fixing and then again before grouting?
Gaz
Personally I would use a cement based adhesive such as mapei keraquick as it doesn't rely so much on absortion to cure which could play a factor if tiling on tile. Ideally seal before you put them up or alternatively seal before grouting then seal again after, twice if possible.
Is Whitestar ok?
Thanks AGAIN!
Gaz
Cheers
Gaz
Whitestar or mosaic fix,One coat of sealer before grouting,and tell customer to apply 1 more including grout lines 2 days after you have finished.Day rate should apply
Thanks guys! I have quoted the job at £200 plus another £100 if she want s the old ones removing.
Hopefully I will get the job now.
Gaz
Hi chaps, just pulling up and old thread of mine to ask a quick question.
I am quoting a job for the same tiles again, 5cm Travertine mosaic. 7m2 with what I would guess some pretty arkward bits and a quite a bit of cutting.
How much do I charge? I didn't get the first one in this thread but could really do with getting this job as I have nothing on after next week. I don't want to do it for nowt though.
Please all opinions welcome, how much do i go in at? I will be doing the sealing once the tiles are fixed with whitestar.
I'm getting about £350 all in but I think it will take a few days for me at least.
Gaz
GazLC81,
felix,
GazLC81,
felix,
