Discuss Mosaic and field tile different thickness? in the British & UK Tiling Forum area at TilersForums.com.
bathroomboy
I have a shower enclosure to do field tile 600x300x 10 m/m horisontal and mosaic 300m/m sq 8 m/m thick in the corners, so a difference of 2m/m any sugestions on this. On borders I have often made a template but with this being a corner and 2 300m/m mosaic mats involved it wont be possible. Any method sugestions please.
Rob Z
Hi BRB,
I have many times made a template/screed that I can use to fill in the area under the mosaics with mortar and then scrape away the excess. Then, allow this to harden and set the mosaics on the modified substrate.
We also have some materials here in the US that can be used to make setting and grouting material, and the mosaics can be set and grouted all in one shot. Dave knows me from a US forum and I think has heard me talk about these products before, but I don't know if they are sold in the UK?
Stan001
I used mosaic spacer a few weeks back putting boarder all the way around a bathroom. I has 5mm glass mosaic inset between 9mm tiles, I used a 2mm thick mosaic spacer. Recon it saved me an hour and loads of stress. Saying that though the price of the spacer sheets are a rip off, 50p worth of plastic molding selling for £10 in my case. So here’s my money saving tip. How you use this stuff is by putting the addy on the wall, placing the mesh on the addy then skimming over the top, the mesh squares will now be filled, then you go over the top with your 3mm notch. To save money cut the mesh up and place it in thin strips, I did this and have enough mesh strips left to do another room, so that’s £5 max a small room rather than over £10. The manufacturers of my mesh (bought from tile Flair – cant remember the make) are cheeky enough to say place two meshes on top of each other for a 4mm spacer. Whaaat? … anyway, I have been looking around for a standard material (maybe used for packaging or some sort of cheap hobby) that I can use as tile spacer. This stuff should be super cheap – if it wasn’t called tile spacer it would be called 'cheap matting' and cost a quid a square metre. I add this to the top of my ‘rip off tilers’ list, one space above ‘square buckets we call washboys’ …. So yooze guys – anyone spotted any cheap matting about 2 ~ 3mm thick (white plastic is perfect) we can buy in bulk from Tesco’s or somewhere?
Oh, second hot tip is to tap panel pins in-between the mosaic pieces to hold up under the mesh, the spacers don’t give enough real estate to hold onto so the mosaics wants to slip down, a panel pin every 300mm or so does the job and is easy to remove.
tfs
Do you make something like this?
Reply to Mosaic and field tile different thickness? in the British & UK Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Hi I've purchased Geo Mosaic Brighton Pattern Tiles (GEO-351) which were sold by Waxman Tiles...
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
6K
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
