Discuss Mosaic kitchen hell in the British & UK Tiling Forum area at TilersForums.com.
dhsanta65
Hi all , I have been doing a mosaic splashback in a over the last 2 days My problem being the tiles are black with a slight stipple on them, I used Bal Mosaic Fix witch is white and has came through the grout lines in some parts which I known I will have to clean out , also it is stuck on the surface on some parts as well and dried out.
Any tips for removing dried in adhesive on a stippled tile.
Grouting with black grout.
Used a 4mm mosaic trowel but still came through.
This is my fist mosaic job ( nightmare )
Any suggestions would be appreciated
Cheers Ian
JEC-CTD
Not tried it myself but I've heard a few people say they've used brick cleaner to do this or even a product called nanoscrub with a decent pad.
Why black mosaic with black grout?
I'm probably teaching you how to suck eggs here but.....
Work slowly and methodically with mosaics, try to get them on and not play with them too much.
Work clean and clean as you go.
Mosaic fix is good stuff but also a bugger, BAL should have called it everything fix cause its like superglue:grin:
Try and find a 3mm trowel and some people like to use a rubber float to move them in to place.
brundlefly
there are a few products on the market for removing addy on the face of tiles
but ive never used Bal Mosaic Fix so dont know how much of a hold it has
you could try HG Extra
broken link removed
or phone Bal technical
BAL ADHESIVES ... on BPi - http://www.bpindex.co.uk/manf.html?id=1060
yep as stated work clean with mosaics, i use a 3mm v notch and tap and move into position with a rubber grout float
Reply to Mosaic kitchen hell in the British & UK Tiling Forum area at TilersForums.com
    • Informative
We used 12x12 mosaic sheets of calacatta marble tile on our shower floor. During installation...
Mosaic kitchen hell
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
