Discuss Mosaics on floor.. flatness! in the Canada Tile Advice area at TilersForums.com.
william hughes
Ive been doing my bathroom and i'm ready to tile the floor. Im planning to put down small white marble hexagonal mosaics that come in standard sheets.
I put down mapei WP200 as a decoupler and waterproofer first. in doing this, and squeezing out air bubbles between the membrane and the adhesive (keraquick) the floor is now not completely flat, there is one or two and even three mm deviation from flat across a 120cm level.
I was nervous about the mosaics before (especially getting them flat). I was wondering whether any of you guys had any tips? i was planning on using keraquick mixed with latex plus and sealing the tiles before.
Cheers!!
Tilerdurden
Cheers!!
Definitely seal prior to install mate. And bal max flex fibre is a good shout. Guessing it's timber sub floor?
william hughes
I always use a large flooring trowel like a plasterers trowel when laying mats. Did you use this technique for smoothing mat out?
yeah i did then notched it. then once it was down went over it again the the flat trowel. to be honest found putting the mat down a pig. trapped air etc
partly why now seeking reassurance before the mosaics. cheers for the advice guys
Reply to Mosaics on floor.. flatness! in the Canada Tile Advice area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Hi everyone, I’ve a fairly basic question I thinks, hope someone can help me out with. I’m...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
